Blown fuse and p0403 code ????
Old Aug 11, 2011 | 01:09 PM
Sharpvet03's Avatar
Default Blown fuse and p0403 code ????
Yesterday the check engine light and battery light came light up on my 2001 Chrysler searing lxi with a 2.7liter. I first checked codes and p0403 is showing up and a blown fuse (02 ssr/alt/egr). I figured the blown fuse made sense with the 0403 code since both are related to the EGR. I figured I had a bad EGR. I replaced the EGR this morning and the fuse. I can start the car and it starts and runs just fine but instintantly blows the fuse. It will blow the fuse by just turning the key to on just before starting.
Any ideas?
Old Aug 11, 2011 | 03:22 PM
Check here:
OBD-II Trouble Code: P0403 Exhaust Gas Recirculation Circuit Malfunction
There's probably a short in the wiring in that circuit. Look for a chafed or damaged wire.
Old Aug 11, 2011 | 03:49 PM
Sharpvet03's Avatar
I checked the connection and unwrapped the wires and retaped about the last 8 inches up tp the connection to the EGR.
Anything else?
Old Aug 11, 2011 | 05:01 PM
Djinn-n-Tonic's Avatar
Look carefully at the exhaust Manifolds where the O2 sensors bolt in...common for burnt and misrouted sensor harnesses......
Also, unplug the field connector from the alternator and re-check for the short.....
And last but not least, find a wiring diagram from IPM . Locate the splice and separate the wires one at a time until you find the shorted one......
Old Aug 20, 2011 | 11:24 PM
helo735's Avatar
any update?
Old Aug 21, 2011 | 10:51 PM
Sharpvet03's Avatar
Originally Posted by helo735
any update?
I had to undo the whole wiring harness to locate a short in a wire that led to the 02 sensor.
Old Aug 23, 2011 | 09:57 PM
TNtech's Avatar
Was it the rear bank downstream?
JimmySiegel
Feb 18, 2015 09:36 AM
anwaypasible
Jun 9, 2011 09:37 PM
stewartsoftware
Apr 17, 2011 03:22 PM
Lorin
Mar 6, 2010 10:12 AM
Master Chief
Aug 26, 2009 07:16 AM
