Chrysler 1996 ( code PO138)
Old Dec 4, 2010 | 08:33 AM
mike/nav's Avatar
Default Chrysler 1996 ( code PO138)
Hello,
On the OBD2 Meter shows this code, does anyone know what is mean or where do I find this sensor. PO 138 02 CIRCUIT HI 9H VOLTAGE BANK 1 SENSOR 2.
I have reset the computer, would that do any harm to the computer.
Thanks.
Old Dec 4, 2010 | 09:49 AM
it means u more then likely have a faulty O2 sensor it would be a down stream o2 past the cat converter
Old Dec 4, 2010 | 11:36 AM
"Bank 1" refers to the bank of cylinders having cylinder #1 in it. On a V-6, that would be the rear bank.
Old Dec 4, 2010 | 10:57 PM
which bank it is would be irrelevant because its down stream and only one down stream on a 96
Old Dec 5, 2010 | 04:06 PM
TNtech's Avatar
A coupe has 4. OP did not tell us the car.
Old Dec 6, 2010 | 06:19 AM
mike/nav's Avatar
Default Chrysler Sebring 1996 2.7 L
Sorry Guys,
After resetting the fault it came on again, can someone let me know where this sensor it located, so I can replace it, it is an easy job or do I need to take it to a shop.
Thanks in advance
Old Dec 6, 2010 | 01:01 PM
1996 did not have 2.7 engines
Old Dec 6, 2010 | 08:56 PM
You'll need an O2 sensor socket and wrench and a way to safely support the car, NOT a jack. Find the exhaust pipe and follow it forward to locate the catalytic converter. Retrace your path to find the downstream oxygen sensor. Unplug it from the harness by lifting the tab on the connector and pulling the connector apart. Don't damage the connector or you're in for a big repair. Using the special tool, unscrew the old sensor and screw in the new one. If the new one doesn't have anti seize compound on it, put some on the threads before screwing it in to make it easier next time. Connect the plug to the harness and you're done.
You may be able to borrow/rent the tool from the auto parts store. Anti-seize compound is sold in little packs sufficient for the job for about a buck.
Old Aug 9, 2012 | 11:44 AM
mike/nav's Avatar
Default PO138 Code on 2006 sebring
Hi can someone help me out a while back I posted the same question, however I made a mistake with the year of the vechicle.
2006 Chrysler Sebring 2006 ( 2.7 L 6 CYLINDER sedan 4 door )
I had the o2 sensor replace, which is located downstream, however the check engine light is still on, however the code is still the same, (PO138) the mechnic suguest its the catalytic converter, however are calling the chrysler dealer they told me that the above car has two catalytic converter.
Question - how would know which one of the catalytic converter is bad , and its that the correct reason check engine light to stay on.
Thanks .
Old Aug 9, 2012 | 02:33 PM
if he used a bosh o2 sensor take it out and but a dealer one in the converter will not turn on the check engine light for that code.
