codes po750 po755 po760 on 96 sebring
Old Aug 22, 2013 | 07:44 PM
jojeremy's Avatar
Default codes po750 po755 po760 on 96 sebring
]Ran a test and these codes came up, transmission control needs to be replace, I pulled the pan but didn't see any sensor can someone tell me where they are located?
Old Aug 23, 2013 | 09:05 AM
You are probably talking about the solenoid pack. Search the forum here and the web in general for lots of information about it. You replace it from the top. It's not in the pan. It's an easy repair. The part is readily available.
Old Aug 24, 2013 | 06:15 PM
jojeremy's Avatar
Default still not working
Replaced the solenoid pack now it's still not shifting, could this be a problem with the wires that connect it to the computer?
Old Aug 24, 2013 | 09:56 PM
If you've dropped the pan and changed the fluid and replaced the solenoid pack, you've dealt with the basic stuff. It's probably time to get it in to a professional with the proper diagnostic equipment to figure out what's going wrong. There may be additional codes stored in the transmission computer that your code reader can't get to. There are hydraulic tests that can be performed with the right equipment.
Yes it "could be a problem with the wires that connect it to the computer" or it "could be" a ton of other things but those are what we call "guesses", and are relatively pointless compared to a proper diagnosis, which is what is really needed.
Old Aug 25, 2013 | 04:19 PM
jojeremy's Avatar
Default now the foward drive dont work
Trying to take it to the transmission shop but the foward drive isn't working what did I screw up?
Old Aug 25, 2013 | 09:14 PM
I have no idea what you screwed up. Were you meticulously clean in your work? Did you clean all the electrical connections? Did you make sure no dirt fell into the valve body when you removed the solenoid pack? Did you mix up the connections for the input and output sensors? Did you use the correct fluid?
Your choice now boils down to backing it all the way to the tranmission shop or calling a tow truck.
Old Aug 26, 2013 | 04:33 AM
jojeremy's Avatar
Driving backwards is an option, IM gonna redo it and clean better and hopefully get back to square one
Jfizzle
Feb 22, 2020 04:37 PM
Newtonn
Jul 7, 2019 11:51 AM
tomcal25
Sep 26, 2012 08:36 PM
Wickman
Apr 17, 2008 03:07 PM
car5car
Apr 6, 2007 04:49 PM
