Convertible top cables
2001 Sebring Convertible
About a year ago my dealer decided that, when I pointed to the weatherstripping at the top of the passenger door and told him that is was no longer tight against the base of the window and allowed water to get into the door, he would ignore me and replace the weatherstripping on the convertible top above the window instead. Aside from doing the wrong thing incorrectly, he also somehow caused the cable that runs along the edge of the top on the passenger side to no longer be in the correct spot. It seems to be ok over the main window, but it is not correct over the top of the quarter window. It allows the white bottom of the fabric to stick out about an eighth of an inch. For now, the problem is only cosmetic. But; 1) I do not know if it will get worse, 2) it seems like it should be an easy fix. Anyone understand what I'm talking about and able to instruct me on how to fix it? Thanks MRR |
I can't imagine how they screwed that up. The cable runs in a pocket of the top fabric. There's no place for it to go.
You might want to contact these guys to see if they can offer any help: http://www.convertibletopguys.com/ |
(Post 27658)
I'll take a look at the fabric. Some of the stitching is coming out in that area, but not where I believe the cables should be. But maybe another section is worn as well and I can sew it up. Now that I know it's supposed to run in the fabric, I have some idea on how to look for a problem. Thanks, MRR |
