Coolant/heating???
I just drained and refilled my cooling system because there was water in it and i replaed it with 50/50 antifreeze. At the same time I replaced my pcm because I had a pcm failure code and the cruise control would kick on for no reason. After refilling the cooling system and replacing the pcm now my heat doesn't get warm. Sometime when I turn the car on the air with blow through the dash even though the control is set to defrost. If I turn the control knob back and forth sometimes it goes back to normal and sometimes it doesn't. I checked the lines the connect to the heatercore and they both get hot. I've read things on this forum about recalibrating the climate control system on diffrent vehicles but I don't know if this can be done on my 01' sebring 2.4 dohc.
Can anyone help me diagnose this heating problem? The weather's getting colder and soon I won't be able to defrost or defog my windows. Any help is greatly appreciated. |
Originally Posted by Matt1118
(Post 102695)
