Cooling fans quit
Thanks Moe....it was the relay.....also took out the fuse....... better than a $$$ trip to the stealer....
Any hints on the best way to flush the cooling system,,,, I want to flush it and refill it Anti-Freeze
Thanks for your help..
COOLING SYSTEM - DRAINING
When servicing the cooling system, it is essential that coolant does not drip onto the accessory drive belts and/or pulleys. Shield the belts with shop towels before working on the cooling system. If coolant contacts the belts or pulleys, flush both with clean water.
WARNING: MAKE SURE ENGINE COOLING SYSTEM IS COOL BEFORE SERVICING. DO NOT REMOVE ANY CLAMPS OR HOSES , PRESSURE CAP, OR OPEN THE RADIATOR DRAINCOCK. WHEN THE SYSTEM IS HOT AND UNDER PRESSURE SERIOUS BURNS FROM COOLANT CAN OCCUR.
[ol][*]Position a clean collecting container under draincock location.[*]Open radiator draincock located at the lower right side of radiator. Turn draincock counterclockwise until it stops.[*]Remove coolant pressure cap and open cooling system bleed valve. [/ol]
LOOK FOR DRAIN ON EITHER LEFT OT RIGHT SIDE OF RADIATOR.NOT SURE.MOE
