Cooling fans quit
Old Dec 5, 2007 | 02:05 AM
SPINNAKR's Avatar
Default Cooling fans quit
The cooling fans on my 03,Sebrings 2.7L quit working.... where can I locate a wiring Diagram for this circuit,,, and how are they fused.....?
Old Dec 5, 2007 | 01:09 PM
moe's Avatar
moe
Default RE: Cooling fans quit
Old Dec 5, 2007 | 01:11 PM
moe's Avatar
moe
hope this helps you!moe
Old Dec 6, 2007 | 12:07 PM
SPINNAKR's Avatar
Default RE: Cooling fans quit....FIXED IT
Thanks Moe....it was the relay.....also took out the fuse....... better than a $$$ trip to the stealer....
Any hints on the best way to flush the cooling system,,,, I want to flush it and refill it Anti-Freeze
Thanks for your help..
Old Dec 6, 2007 | 02:50 PM
moe's Avatar
moe
COOLING SYSTEM - DRAINING
When servicing the cooling system, it is essential that coolant does not drip onto the accessory drive belts and/or pulleys. Shield the belts with shop towels before working on the cooling system. If coolant contacts the belts or pulleys, flush both with clean water.
WARNING: MAKE SURE ENGINE COOLING SYSTEM IS COOL BEFORE SERVICING. DO NOT REMOVE ANY CLAMPS OR HOSES , PRESSURE CAP, OR OPEN THE RADIATOR DRAINCOCK. WHEN THE SYSTEM IS HOT AND UNDER PRESSURE SERIOUS BURNS FROM COOLANT CAN OCCUR.
[ol][*]Position a clean collecting container under draincock location.[*]Open radiator draincock located at the lower right side of radiator. Turn draincock counterclockwise until it stops.[*]Remove coolant pressure cap and open cooling system bleed valve. [/ol]
LOOK FOR DRAIN ON EITHER LEFT OT RIGHT SIDE OF RADIATOR.NOT SURE.MOE
jammozzz
Jan 19, 2011 04:05 PM
sleepymechanic
Jan 11, 2011 10:27 PM
gbeach
Jul 1, 2008 11:12 AM
gbeach
Jun 30, 2008 05:01 PM
seawind3000
Apr 9, 2008 12:05 PM
