could dealer put on wrong size oil filter?
Old May 4, 2011 | 11:49 PM
08retract's Avatar
Default could dealer put on wrong size oil filter?
I am new to all this.
I have a 2008 sebring with a 2.7 liter engine with only 14000 miles.
I have been wanting to change the oil for the first time as a new owner.
The car has small dia. filter on it. I haven't taken it off yet.
Yet, whenever I look in the book, it calls for a large diameter filter.
The book calls for Mopar 04884899AB
and is equivalent to Fram PH 16 or Fram PH 2.
and I understand the PH 2 is the one that has the 22mm thread which is what my 2008 car has, I think.
These are both the large diameter Filters.
My question is... could the dealer install a small diamter filter where a large diameter filter should be?
And should I install the PH 2 or equivalent? Regardless of what the dealer installed before?
HELP HELP HELP...thanks..
Old May 5, 2011 | 06:22 AM
different maker of filters make different size U cant go by that and no the dealer did not install the wrong one.
Old May 5, 2011 | 07:32 AM
DrGadget's Avatar
On my last oil change,they put a smaller diameter filter but it was a little longer than the last one,so I guess it evens out.
Old May 5, 2011 | 08:50 AM
08retract's Avatar
so... regardless whats on the car now,
I will be ok installing the mopar filter that is called for in the owners manual which is Mopar 04884899AB.
Or equivalent.
These are all large diameter filters/ with the 22 mm threads. I looked at all the stores.
The filter on the car now... has the small diameter.
Sure is confusing.. never have had this problem before!! on my other rigs..
Thanks..
Just a general question. As long as the threads match,
can either a large diameter or small diameter filter be installed on any vehicle?
Old May 5, 2011 | 09:22 AM
The gasket must seal on the proper surface.
Old May 5, 2011 | 10:02 AM
08retract's Avatar
makes sense, thanks..
and thanks to everyone else that helped me out.
Old May 5, 2011 | 09:57 PM
ModdedLHS_2011's Avatar
Yes sometimes they do get things mixed up
Old May 7, 2011 | 01:29 AM
hesse2115's Avatar
it is possible, but you would know if they did after driving it for a while and you punch the gas. the filter will actually blow off of the threads and leave a trail of oil
Old May 7, 2011 | 09:43 AM
08retract's Avatar
found out...wrong filter was on car!!!
Filter was from Jiffy Lube, not the Dealer.
Makes you kinda wonder about doing business with these guys.
Old May 7, 2011 | 09:52 AM
08retract's Avatar
Jiffy Lube put on wrong filter...not dealer.
Kinda make you wonder about doing business with these "oil change businesses".
