Crankhouse pressure relief
Old Jul 17, 2020 | 06:29 AM
Tigermouse's Avatar
Default Crankhouse pressure relief
Hi
My 2.7 at 200000 Kms uses 1L of oil per 1000 KM. ( 120000 Mls and a quart every 600 mls ) and I suspected the engine to suck it all in.
Removing the tube from valvecover to inletmanifold shows oilmist coming out.
Can I:
Plug the connection
Plug the inlet on manifold and let tube end in a bottle to collect oil as condensate to avoid spill, thereby avoiding the extra consumption due to the vacuum.
Jan
Denmark
Old Jul 17, 2020 | 10:53 AM
Check the PCV valve.
The PCV valve should function to reduce pressure in the crankcase.
Run a compression check to determine if there is excess blowby due to worn piston rings.
If that's an issue and you don't want to spend the money for a ring job, consider something like this:
Amazon Amazon
Johnny Nitro
Oct 9, 2020 01:34 PM
robertwstn
Sep 7, 2016 09:22 PM
rickseminole
Mar 22, 2015 05:20 PM
funjon1
Jan 11, 2009 11:33 AM
cjsturgeon
Mar 2, 2008 05:59 AM
