Desperate for help...'97 V6 bad misfire cylinder 5
Old Sep 10, 2009 | 12:54 AM
cjhstang's Avatar
Default Desperate for help...'97 V6 bad misfire cylinder 5
Tearing my mom's intake off for the 4th time attempting to fix or atleast diagnose a misfire in cylinder 5.
Have a new cap, plugs, injector, wires, timing belt(2 yrs old) and battery.
Planning on doing a compression test in the morning. Any ideas on the problem? Are these engines known for a certain fault causing this misfire? i've noticed i'm not the only one around with a cylinder 5 misfire.
and a second question. what is the compression I 'should' have on this car?
...it does have 160k on it.
Thanks for any help!
Old Sep 10, 2009 | 11:27 AM
cjhstang's Avatar
did compression test. (first time i've done one...)
first round of check
cylinder 1 - 175
cylinder 2 - 175
cylinder 3 - 200
cylinder 4 - 165
cylinder 5 - 200
cylinder 6 - 225
second round of testing they all showed 225 psi.
don't fully understand that, i let the engine warm up before i started testing.
also pulled sparkplug on cylinder 5 plugged it into the wire and cranked. saw a small spark with crackling on each revolution. (i hooked the threaded area up to a jumper cable and attached other side of cable to neg of battery). DId not see a spark religiously every revolution though, I DID hear crackling each revolution. I've understood that to be normal?
Either way it has a new plug wires and cap so spark should be fine.
anyways, where should i go next? still don't understand this cylinder 5 misfire.
Old Sep 11, 2009 | 08:46 AM
do u have the gap right and what about champion plugs?
Old Sep 11, 2009 | 09:52 AM
cjhstang's Avatar
I did not regap the plugs. The plugs that were in it when this issue started were only two years old. I replaced the plug for that cylinder with a new one but still the same problem.
Two thoughts I had was maybe a bad computer or possibly a bad wire going to the cylinder five injector?
Car drives fine off idle, but at idle its terrible.
Cleared codes after compression test, still kicking cylinder 5 misfire code.
Like the web site!
Old Sep 11, 2009 | 10:40 PM
more like internal engine like sticking valve or carbon on the valve the pcm does not make a single cly misfire on a distributor system.
Old Sep 12, 2009 | 04:41 PM
cjhstang's Avatar
hmmm that makes sense...
That wouldn't show up in a compression test?
guess there is no easy way of fixing that is there??
Old Sep 12, 2009 | 08:39 PM
decarb the pistons
Old Sep 12, 2009 | 09:39 PM
cjhstang's Avatar
yeah i understand that... but is there anyway i can do that without having to pull the heads?
I've read posts about people putting seafoam into the intake to clean the intake valves?
Old Sep 13, 2009 | 06:49 AM
that's what I as talking about directly into the intake and into the cyls it will make a lot of smoke.
Old Sep 13, 2009 | 10:11 AM
cjhstang's Avatar
so i'm putting this stuff in it while the car is running?
Or am i doing it with the car and intake off?
Thanks for your help
