Dumb ? - please help
Old Oct 20, 2006 | 08:54 PM
isabel's Avatar
Default Dumb ? - please help
Hi, my stepbrother left his 2002 Chrysler Sebring with me for 6 months while on deplyment and I have no use for it. We stored it in a barn and I assume I should disconnect the battery so it does not lose charge. I could not find the battery! So, please, where is the battery and how would I dsconnect safely?
Thanks, Izzy
Old Oct 26, 2006 | 05:12 PM
Oddman's Avatar
Default RE: Dumb ? - please help
It should be in the drivers side wheel well. You'll need to remove the front wheel, and remove the wheel well and you'll find it.
Old Oct 26, 2006 | 05:27 PM
isabel's Avatar
Thank you for the response. I do notice cables running from that direction up above to where I can access them. Do you know if I could just remove the (-) cable there or do I need to go directly to the battery? Thanks again, I
Old Oct 28, 2006 | 04:36 AM
Oddman's Avatar
You can disconnect the (+) and (-) wires from the engine compartment, they should be clearly marked. but it would be best to disconnect at the battery.
dedwardk
Apr 28, 2013 05:09 PM
hungryhemi
Jan 5, 2011 01:03 PM
pacifica gal
Jun 13, 2008 09:06 AM
SARG
Apr 7, 2008 09:42 PM
Mar 15, 2006 08:08 AM
