Electrical Starting Problem - Blowing Fuse
Old Jan 10, 2011 | 10:33 PM
TRev's Avatar
Default Electrical Starting Problem - Blowing Fuse
I own a '98 Sebring Jxi 6-cyl. Conv. that is blowing the 20-amp fuse, #8 Ignition fuel starter, located in the engine compartment fuse box. The problem started after a big rain just sitting, not driving (co-incidence?) It only happens when I try to start the car. The fuse does not blow with the key in the ignition position, but when I try to crank the engine over -the fuse blows. I get no error lights and lose the display when the fuse blows. I hear nothing, no clicking, no relay engaging because the fuse blows first. I eliminated the starter by removing the cable running to the starter - but the fuse still blows. The battery is charged and even jumping the battery didn't keep the fuse from blowing, so it's not a weak battery problem. Radio on or off makes no difference. I checked the resistance on all the relays. Since they all are the same P/N I moved them around but this didn't change anything either, so I don't think it's a relay problem. Any ideas?
Old Jan 10, 2011 | 11:33 PM
a wire or what ever the fuse powers up is shorting it out
Old Jan 11, 2011 | 10:22 AM
Gridwiz's Avatar
Default I had the same problem...
the starter was arcing out on the nearest metal. We pried it alittle further away and it has not returned. I was going through about 10 or so fuses a week for about a 6 months before my buddy had it lifted up and noticed how close it was. I hope this helps.
Old Jan 11, 2011 | 05:48 PM
Djinn-n-Tonic's Avatar
Ive seen quite a few of these which can go either way...It isnt nearly out of the question for a starter motor itself to do this.
PolarisCobra
Jul 10, 2007 03:06 PM
prince71
Oct 20, 2006 03:49 PM
prince71
Oct 19, 2006 12:55 PM
ragtop71
Jul 13, 2006 03:54 PM
v1rott
May 8, 2006 08:23 PM
