FACT OR FICTION ON THE 2.7 SWAP FROM 04 TO 01
Old Feb 23, 2008 | 08:48 AM
rjasp2000's Avatar
Default FACT OR FICTION ON THE 2.7 SWAP FROM 04 TO 01
Im not really sure if anyone really knows what is fact or fiction. I have rebuilt alot of different motors over the years diesel and gas. The only differance in one from the other is a computer,sensers, and fuel injection. So this swap must be possible. Some how some way. I think if we all stand up to the plate with all of ower experiences this can happen. So lets make this happen. thanksRuss rjasp2000@yahoo.com
Old Feb 23, 2008 | 09:02 AM
rjasp2000's Avatar
Default RE: FACT OR FICTION ON THE 2.7 SWAP FROM 04 TO 01
Here are somethings that I have been reading go to this site http://dodgeforum.com/m_1143428/tm.htm and read below
Sent to Dodge Experts June 15, 2007 5:58 a.m.
[hr]
this question is for dan havner please explain again (crossfire tech)
I have a 2001
dodge grand caravan (awd) 3.8L. The engine blew so I replaced it w/ a 2005 dodge grand caravan 3.8L. I had to switch the top part of the engine with my 01 parts. I also used the flywheel from the 01. When i went to start it back fires at the manifold. I took the intake manifold off and tried to start and it fires out of all cylinders but it's off. Van is fireing with valves open w/ intake stroke. I changed the crank sensor and cam sensor still same problem. One dodge dealer said that the flywheel and crank shaft is different so an 05 engine cannot work with 01. Another dodge dealer said thats not true because its the same short block so the engine is same i just neet to change top (which i did). Is the crankshaft the same for 05 and 01? Also I know that the flywheels are different but im using the 01 flywheel. Also are the crankshafts different, some people say yea some say no. [/align][/align]
Customer (name blocked for privacy)
Status: ClosedValue: $15
Answer
June 15, 2007 6:21 a.m. (23 minutes and 17 seconds later)
ACCEPTED
[hr]
I am not cross fire but can help you with this problem.
The Flexplate is not the right part number for the model year.
Make sure the correct Flexplate is used if doing an engine swap. There are major differences in the spacing of the Crankshaft Position (CKP) Sensor slots in the Flexplate used on vehicles equipped with a Single Board Engine Controller (SBEC) III and vehicles equipped with the Next Generation Controller (NGC). The 1995-2003 models use the SBEC III, which has two 40-pin connectors. The 2004 models use the NGC, which uses four 38-pin connectors. Using the wrong Flexplate will usually result in a no-start. To avoid problems, use the original Flexplate from the vehicle or the correct new part. The Flexplate used on vehicles with an SBEC III engine controller has 3 groups of 4 slots spaced around the circumference. The Flexplate used on vehicles with an NGC has a slot every 10 degrees around the circumference except for one long slot where 2 slots are joined and 180 degrees around from that an area with 2 filled slots (a solid section).
The Camshaft Timing Gear is not the right part number for the model year.
Make sure the correct Camshaft Timing Gear is used if doing an engine swap. There are minor differences in the spacing of the Camshaft Position (CMP) Sensor slots in the timing gear used on vehicles equipped with a Single Board Engine Controller (SBEC) III and vehicles equipped with the Next Generation Controller (NGC). The 1995-2003 models use the SBEC III, which has two 40-pin connectors. The 2004 models use the NGC, which has four 38-pin connectors. Using the wrong Camshaft Timing Gear will usually result in a no-start. To avoid problems, use the original Camshaft Timing Gear from the vehicle or the correct new part
Edited by marc on 15 June 2007 at 6:23am
__________________
If you have further questions please post back.
If my answer was helpful please click on the ACCEPT BUTTON Thank you Marc [/align][/align]
Old Feb 23, 2008 | 09:50 AM
powers84's Avatar
on my swap that still wont fix the no fuel promblem.
Old Feb 23, 2008 | 12:09 PM
rjasp2000's Avatar
The fuel problem you are having could it be what they are talking about , the flex fuel and non flex fuel. They say you have to change the fuel injectors,intake, and cam sprokets to make this work.
Old Feb 24, 2008 | 02:35 PM
powers84's Avatar
no i dont think that is it it has to be the computer it runs everything the only solution i can think of is to swap to the right engine or change all electical system over which nobody knows how.
Old Feb 24, 2008 | 11:57 PM
rjasp2000's Avatar
and yes the people I have talked to say yes to the flex and non flex fuel. The way it looks is the cam gears, flywheel,injectors,intake cam and crank sensors have to be changed. So if you used the new flywheel you have to pull it to change it. I am going to get more info tomorrow on the motor from the 04 I am suppose to get. I will probably get a motor out a 01-03 to make it simple. good luck
Old Feb 25, 2008 | 08:50 AM
powers84's Avatar
yeah im pulling it today thanks for the info. you know anyone that needs a 04 engine its going to be for sale really soon.
gottalebaron86
Aug 26, 2008 10:08 PM
andbudzi
Feb 20, 2008 04:07 PM
dave23bme
May 23, 2006 03:57 PM
GreenCar
Jan 12, 2006 03:00 PM
PDQ Hemi
Sep 4, 2005 04:47 PM
