Fuel Line replacement 96 Sebring JX conv
Ok brakes lines are just about done. Need to get the last wheel done, then have a mechanic come over pressure test and bleed. Im trying to get as much info on the fuel lines as I can. The questions I have is / are : 1. Is the only reason to depressurize the fuel system is so that gas wont be spraying all over the place. What damage can I do, if any, if I dont depressurize ? 2. Is a fuel line routing diagram available ? Chiltons dont show one and neither does eautorepair.net. I can trace them, but up toward the engine they disappear into Neverland. The two fuel lines run in parallel with the rear brake lines. Problem is, I dont know which is supply and which is return and how the fuel line is mated to connection points (flaring etc ??) 3. Can I get to the lines by taking the rear seat out ? The book mentions that access is possible with the 98, but doesnt mention any other year. Thanks in advance for the replies. |
RE: Fuel Line replacement 96 Sebring JX conv
well if u are replacing the lines u wont have an option but to do so its only 55 psi of pressure u will spray some in your eyes just use common sence put a rag over where ever u start to disconnect the line.
No diagram either haft to manualy route it take a pic of where tehy are now and make them. I think that is 98 only as well haft to look and see. |
Thanks, alot Chryslertech ..
How bout the connection points ? Are they flared ... 45 inverted ? Also I found this on our sister site dodgeforums.com... also own a 06 Mega Cab .. ------------------------------- De-pressurizing the fuel system ------------------------------- 1. First you must de-pressurize the fuel system, so you ask how the in the heck do I do that?? -Now as well all know gas is real combustable so safty first absolutlyNO SMOKING of any kind while doing this. -Remove the rear seat cushion and look for the metal plate it's on the drivers side. It should have 4 small screws holding it in place. Unscrew those and gently raise the cover. -Now your looking at the top of your fuel pump. Look for the wire clip, and unplug it. The other cover is the fuel level sender ( in the middle) -Start the engine and allow it to run until it stops. It should only take a second. Crank the engine 1 more time to ensure that all pressure is relieved. - Now disconnect the negative battery terminal before doing anymore work. Will this do for depressurization ? |
