Fuse 23
Old Jul 26, 2021 | 07:34 AM
Wes78's Avatar
Default Fuse 23
Hi all, first post. 12 Chrysler 200 2.4, keeps blowing asd fuse 23. Had a friend look up the schematics on Mitchell and if I’m reading it right fuse 23 is most closely related to the coils? Everything gets blurry in the TIPMS. I can drive it for a bit and then fuse 23 blows. Sometimes days sometime weeks and sometimes hours. Any one have a clue of where to start? I was originally thinking fuel pump may have been pulling too many amps and blowing the fuse but then the schematic pointed me to the spark.
Old Jul 26, 2021 | 01:16 PM
DavidBoren's Avatar
I don't have any experience with this particular issue... but when electrical crap starts going wrong, I always start with the grounding straps/cables. A loose ground is a gremlin that can cause a lot of other problems.
Old Jul 27, 2021 | 07:53 PM
Wes78's Avatar
thanks man, trying to track those down now. Looks like I’m going to have to get into mitchell1
Old Jul 27, 2021 | 11:16 PM
DavidBoren's Avatar
Looks like it is supposed to be a light blue 15 Amp fuse that goes to the Auto Shutdown (ASD) Relay 3...
ASD relay stuffs
Hope that helps, it is all I could really find.
Old Jul 28, 2021 | 06:06 AM
Wes78's Avatar
Thanks man, that was extremely insightful. In the 200 the relay is built into the tipm and as far as I can tell not actually serviceable. Think you are spot on with the grounds. Thanks again
Old Jul 29, 2021 | 11:21 AM
Faulty or loose grounds do not cause a short to blow a fuse. a Blown fuse is caused by an item that has power going to is to instantly go to ground with out going through the seid item first like a lite bulb switch motor . The fuse is there to protect the system from a short to ground and would cause a fire , melt wires and take out modules. If the fuse only blows after certain times like driving for a little bit or hitting a bump something to change what the currant status is thats what and where you would look for it. A harness sitting on metal rubbing away at the coverings. Also could be something getting to hot and the resistance is to high aka coil , motor something like that. SO first need to track down WHEN it happen then you can see what is the likely cause from that.
paulstevens
Sep 2, 2016 09:47 AM
Melssj5
Apr 25, 2012 10:03 PM
TRev
Jan 11, 2011 05:48 PM
myke212
Cirrus & Breeze
Jun 15, 2009 01:25 PM
jatislost
Jan 7, 2009 05:19 PM
