guys help please
i just installed a remote car starter. i dindt finish it because i cant find the exact location of my tach wire. on my diagram it says that is in powertrain control module, and the color is white/brown. i access the pcm but i coulnd't find that color. and also maybe you have an idea also of the wire color of ignition from skimm immobulizer? those 2 wires are the last wires that i need to hook up. so i can test the remote start if it will run. please guys help me..
pls tell me the location of tach wire and color and for the immobulizer also. thanks in advance.. more power |
need to know year make and model of car with engine size
(Post 66151)
there is not a tach wire its a PCI bus network the speedo,tach, coolant and anything else u see on the cluster is voltage on a single wire bus network
(Post 66160)
(Post 66163)
Go back to where you bought that starter system and ask them how to hook it up. If you can't do that, go to a place where they install remote starters for a living and either pay them to finish the job or make friends with the technicians (bring a box of doughnuts) and get their advice.
(Post 66185)
Pretty sure you should go with the green wire. I went to install a tach on an older vehicle and had the same two choices, green or black. The green was what needed to be hooked up in order for it to work. Not 100% sure, but if you have 2 wires, and one doesn't work, odds are the other will! I've never hooked up a remote starter, but if all that's holding you back is that wire i'd try it out. Wish i had more advice to give you.
