hazard flashers
Old Feb 27, 2021 | 04:28 PM
malc4d's Avatar
Default hazard flashers
My hazard flasher work with the ignition on but not when switched off. Any ideas ?
Old Feb 28, 2021 | 06:59 PM
That's a real head scratcher. When you say "with the ignition on" do you mean with the engine running? If so, maybe it's a weak battery that can only drive the system when the generator is putting out current. If it's not with the engine running then that can't be the answer. The flasher and the turn signal are both controlled by the same device, which is plugged into the multifunction switch. You would expect that the turn signal would exhibit similar behavior.
Old Feb 28, 2021 | 09:45 PM
malc4d's Avatar
Thanks for answering.
Further checking the multifunction switch has power going to both the switched + and battery + inputs, so I'm going to swop over the switch with my other car tomorrow and see.
Old Mar 2, 2021 | 04:51 PM
malc4d's Avatar
swopped over switch and its definitely the problem.
tmizzle
Aug 11, 2020 07:32 PM
fyshbyte
Jun 27, 2018 09:15 PM
Ddman
Dec 3, 2014 10:44 PM
sdeal5
Jun 29, 2013 10:51 PM
Ayce
May 18, 2009 08:44 AM
