heater
Old Jan 27, 2007 | 01:33 AM
jsvascular's Avatar
Default heater
Aside from this site being much too cumbersome (it is not overtly clear how to pose a question) I pose, to Chrysler engineers or whomever has the answer, why does my 2000 Sebring car heater initially blow hot air within 5 minutes of starting the engine, then cools down and doesn't again blow hot air until about 15 minutes of running the engine? My mechanic topped off the coolant; still have the problem!
Old Jan 27, 2007 | 02:31 AM
Default RE: heater
air bubble trapped in heater core.If u have a 2.7l engine its common for some one that does not not know to fill the coolant system up with the right tool.
IS your heater core,water pump or Water outlet housing leaking. Air can be trapped if there is a leak in any of thoes places.
Old Jan 27, 2007 | 05:08 AM
jsvascular's Avatar
Default RE: heater
This problem began last winter, and there was never any overheat of the engine thru this past summer, so I doubt a low coolant problem or a leak. Also, why would the engine jacket/heater coil system, as it first heats up, and after supplying hot air, then deliver cool air, and then return to a continual supply of hot air? I sense that perhapsthere is a thermostat connection between the engine jacket and heater coil that is over reactive and isclosing the initial hot water supply to the heater coil. But is there such a thermostat regulating delivery of water to the coil? I didn't think so; I thought the engine jacket/heater coil system was one continuous open system. The VIN is 3C3EL55H9YYT313?82, in case this tells you the engine size, a V-6. You seem to know your stuff. Thanks for the input. Any more ideas? I guess its time to look under the car for a leak. What's this about a tool to insert coolant? [/align]J.Steinberg[/align]
Old Jan 28, 2007 | 01:40 PM
mrrbby's Avatar
Default RE: heater
My 2000 Sebring convertible was doing the same thing. No leaks, head gasket aren't blown, and the water pump/timing beltand coolant hoses recently replaced by the dealer(not leaking, just due for replacement). I had a proper flush and fill done, and it no longer does this. It does sound like an air bubble in the system.
Old Jan 28, 2007 | 02:07 PM
Default RE: heater
well u have a 2.5 engine there are not any usual things as far as no eat with them look for a leak and if the thermostat was stuck close u would over heat and stuck open the guage would be in the low range while driving.
Old Jan 28, 2007 | 03:17 PM
jsvascular's Avatar
Default RE: heater
To mrrbby and chrysler tech:
Thanks so much for the input. Sounds like its time for a flush and fill, with the 'proper tool'. I'll look into this latter issue, unless the chrysler tech can offer info on that. Again thanks.
jsvascular
Old Feb 9, 2007 | 11:16 AM
mrrbby's Avatar
Default RE: heater
Any luck?
Old Jan 20, 2008 | 09:32 PM
Sebring05's Avatar
Default RE: heater
How does one go about bleeding the heater core to get the air out?
Old Jan 22, 2008 | 08:03 PM
seawind3000's Avatar
Default RE: heater
In the first 5 min the anti-freeze in the engine block warms and travels through the heater core then the thermostat opens and the cold anti-freeze in the radiator system goes to the engine block and heater core ( your 15min of cold air) then the engine warms all the anti-freeze and the warm air returns. The thermostat could be sticky at start up.
Mike
elpaso
Cirrus & Breeze
Aug 8, 2011 05:30 PM
skywalker
Jan 22, 2011 08:19 AM
elpaso
Aug 25, 2005 01:11 AM
klownboots
Jul 11, 2005 08:24 PM
jayunit1689
May 22, 2005 01:38 AM
