help 2.7 motor
Thanks I did buy a 2.7 motor with 16000 miles on it out of a 04 sebring sedan. The only differance is the egr valve. I should be able to swap the rear exhaust manifoldand intake from my motor to the new one. Is there anything I can do to get the most out of this new motor? Everyone has this slugging build up problem. Can something be done to stop this? Is there a certain kind or oil I should use to get a longer life out of this new motor?What would you do?thanksRuss
RE: help 2.7 motor
one word "SEAFOAM" you can buy it at your local auto supply store, read the label. This will keep the sludge fron forming and clean build-up that may already be there. I put 1/2 a can in the crank case and the other 1/2 in the gas tank, this keeps the fuel system and the engine clean.
Mike |
RE: help 2.7 motor
plus use 5w30 oil
RE: help 2.7 motor
ORIGINAL: rjasp2000 Thanks I did buy a 2.7 motor with 16000 miles on it out of a 04 sebring sedan. The only differance is the egr valve. I should be able to swap the rear exhaust manifoldand intake from my motor to the new one. Is there anything I can do to get the most out of this new motor? Everyone has this slugging build up problem. Can something be done to stop this? Is there a certain kind or oil I should use to get a longer life out of this new motor?What would you do?thanksRuss |
RE: help 2.7 motor
its not the amount of oil changes. its the engine design stinks!these guys are right about the oil grade and sea foam stuff!
