help 2.7 motor
Old Feb 17, 2008 | 07:54 PM
rjasp2000's Avatar
Default help 2.7 motor
Thanks I did buy a 2.7 motor with 16000 miles on it out of a 04 sebring sedan. The only differance is the egr valve. I should be able to swap the rear exhaust manifoldand intake from my motor to the new one. Is there anything I can do to get the most out of this new motor? Everyone has this slugging build up problem. Can something be done to stop this? Is there a certain kind or oil I should use to get a longer life out of this new motor?What would you do?thanksRuss
Old Feb 17, 2008 | 08:17 PM
seawind3000's Avatar
Default RE: help 2.7 motor
one word "SEAFOAM" you can buy it at your local auto supply store, read the label. This will keep the sludge fron forming and clean build-up that may already be there. I put 1/2 a can in the crank case and the other 1/2 in the gas tank, this keeps the fuel system and the engine clean.
Mike
Old Feb 17, 2008 | 10:56 PM
plus use 5w30 oil
Old Feb 20, 2008 | 05:49 PM
tarbaby's Avatar
ORIGINAL: rjasp2000
Use Amsoil Full Synthetic 5W30. You will never have the problem again.
Old Feb 21, 2008 | 03:13 PM
moe's Avatar
moe
its not the amount of oil changes. its the engine design stinks!these guys are right about the oil grade and sea foam stuff!
Tonys02TNC
Apr 26, 2011 11:52 AM
ronsemko
9
Feb 10, 2011 12:33 PM
keefer
Aug 5, 2010 07:33 PM
dhhbomb
May 21, 2008 04:15 PM
mazdaboy873
Sep 19, 2007 10:33 PM
