Help, My rear passenger window jams up.
Hi all,
I've already taken everything apart, and I know what I need, I'm just hoping someone here can point me in the right direction. My window has trouble sometimes going up/down. It has trouble because the cable is all loose and gets jammed in the motor/spool thing. It is loose because a spring popped out. The spring that popped out is the one for the upper cable. It popped out because the white plastic piece at the end of the cable broke. I also lost one of my white plastic square grooves that keeps the cable from rubbing against the metal. I have a parts list for this car, but there's nothing about these pieces. Can anyone help me? Thanks, -==- Nick |
because the parts on the regulator are not serviceable u replace the whole thing.
Try a junkyard for parts like that.
