Horn Sebring 2006 2.7 l
Old Nov 9, 2009 | 06:39 AM
mike/nav's Avatar
Thumbs down Horn Sebring 2006 2.7 l
Can someone let me know which fuse control the horn,also is there any other circuits on that same fuse.
A while back I ask for help on the alarm issue, however it doesn't seems to be the factory alarm, it the horn, during the night the horn will go on for 5 min and stop, last night it went on twice 5- 10 min apart, its starting to get to me, please help.
Thank you
Old Nov 9, 2009 | 03:15 PM
Look under the cover of the fuse box for a legend as to what each fuse controls. There are two fuse boxes, one under the hood and one under a cover at the driver's side end of the dash.
Do you have a red light flashing on the dashboard when you lock the car electrically? If so, it's the factory alarm. If not, it's an aftermarket system.
Old Nov 10, 2009 | 06:39 AM
mike/nav's Avatar
Thanks for your reply.
Its the horn, there no (red light flashing on the dashboard ) sometimes while I am driving the horn will goes on , it is the right side, I would just press the right side and it will stop, I purchase this car 5 months back, at that time there was no issues, I also call chrysler canada to see it is cover but is not, I have no choice but to have it fix, it seems it would cost around 4 hundred dollars to fix,@ the dealer are there any one who had this problem.
Is there any one in Toronto you can fix this cheaper.
mikebelairgt@yahoo.ca
Old Nov 10, 2009 | 06:36 PM
Sounds like you have a problem in the wiring leading to the horn. There's a horn relay in the junction block (left end of the dash), but (assuming you have two horns) the relay controls both horns, and if it was acting weird, you should hear both of them.
The reason this is expensive is because of the labor required to just get to the horn. You have to pull the bumper cover off to access it.
Old Dec 2, 2009 | 05:21 AM
Neretees73's Avatar
Default Horn Sebring 2006 2 7 l
We dont get much of Chryslers, but we did a Sebring the other day and was just curious how difficult everybody thinks the B/G is?
co6571
Nov 15, 2010 06:18 PM
exit9sebring
Jun 26, 2007 04:30 PM
crazyjoe86
Apr 19, 2007 03:39 AM
exit9sebring
Apr 11, 2007 01:20 PM
kenny
Dec 23, 2006 12:34 PM
