How do I loosen the power steering support bracket in 1999 JXI?
Old Nov 22, 2010 | 05:56 AM
illumitech's Avatar
Default How do I loosen the power steering support bracket in 1999 JXI?
I'm trying to get the top left cam timing cover off to replace the timing chain and the cover is blocked by the power steering support bracket. Already have loosened and set aside the power steering pump. Found two bolts holding the power steering support bracket under the car and removed them.
There is at least one bolt between the cylinder heads and the firewall. I removed the upper intake manifold and I still can't get a socket on it. Has anybody come across this problem? How many bolts are behind there and what size heads are they? Any help would be greatly appreciated as I am dead in the water until I can get that darned PS support bracket moved. Thanks!!!
Termite
Sep 4, 2011 01:52 PM
bigrobot
Nov 30, 2010 12:30 PM
bumu
Feb 18, 2007 01:44 PM
allenl44
Sep 16, 2006 12:21 PM
allenl44
