Intermitten PO344(Cam Position Sensor)
Old Oct 17, 2010 | 09:33 PM
beast39's Avatar
Unhappy Intermitten PO344(Cam Position Sensor)
Hi all: I just registered because my daughter has a 2005 Chrysler Sebring 2.4 with about 110K miles. She has had this problem before and the cam position sensor was replaced about a month ago and it had been running ok for about 2 weeks. Now the DTC PO344 comes on for about a week and then clears itself for another week and then decides to come back. The cam position sensor had been replaced in early August before this last replacement. When the code is on the car spits and sputters. Because the code is not consistent I do not believe it is a bad CPS. I have been told that there is a TSB 18-015-09 which refers to this intermitten PO344. Has anyone had this problem and has it been resolved? Does anyone have a copy of said TSB, would appreciate a copy.
Thanks,
Old Oct 17, 2010 | 11:12 PM
that TSB is not for your car
check for your 2 5v and ground at the cam sensor
Old Oct 19, 2010 | 09:00 AM
beast39's Avatar
Thanks for the response. Could you please be more specific as I do not know what you mean. Are you saying to check the voltage, if so on which wires and on what status of the engine operation. Really appreciate the help!
Old Oct 19, 2010 | 09:18 AM
key on not running U will have 2 wires that will have 5 volts and one with a ground
CAMSHAFT POSITION SENSOR - BLACK 3 WAY CAV CIRCUIT FUNCTION
1 K6 20VT/WT 5 VOLT SUPPLY
2 K4 20BK/LB SENSOR GROUND 1
3 K44 20TN/YL CMP SIGNAL
Old Oct 19, 2010 | 05:30 PM
beast39's Avatar
Thanks for the prompt response. I did not know if the test was to be done with the cps connected or disconnected. So I disconnected it and I get nothing at the connector with the key on engine not running. How is the test suppose to be done?
Old Oct 19, 2010 | 09:50 PM
this is over your head then let a pro take a look at it
Old Oct 20, 2010 | 08:50 AM
beast39's Avatar
Thanks for the response. I would love to be able to take it to a pro but my daughter can not afford it financially, she's unemployed and has been for 4 months. I have a Haynes Manual # 25040 but it does not contain electrical schematics for the engine or detailed instructions for such test. Any other help you can provide will be greatly appreciated.
Old Oct 21, 2010 | 08:24 PM
TNtech's Avatar
PM me your e-mail and i'll send you the test in PDF format. Make sure the wiring harness isn't rubbing the back corner of the cylider head on the driver's side.
Old Oct 22, 2010 | 10:05 AM
beast39's Avatar
Thanks for the response. I will check to see if the wiring harness is rubbing agains the back corner of the cylinder head. Email: ombenavides1@yahoo.com. I really appreciate the help and look forward to getting the test!
Old Oct 22, 2010 | 09:31 PM
TNtech's Avatar
Originally Posted by beast39
Thanks for the response. I will check to see if the wiring harness is rubbing agains the back corner of the cylinder head. Email: I really appreciate the help and look forward to getting the test!
Sent. Delete your e-mail now if you want.
