Intermittent Sebring Air Conditioner
Old Jun 24, 2017 | 08:03 PM
Ericbo101's Avatar
Smile Intermittent Sebring Air Conditioner
My Sebring air conditioning is working great, recharged it a couple of times and it's pretty cold ... But once in a while it just blows warm air. I just went to check it and of course it works perfectly fine now
Any idea what could be the problem ?
Much appreciated !
Old Jun 25, 2017 | 03:50 PM
Temperature of the discharge air is controlled by the "blend door" which mixes outside air with heated or cooled air to control the air temperature. If I'm not mistaken, you can see and service the blend door actuator from under the dash without removing the whole system. While that's one possible source of the problem, it's not the only one. Other possible trouble areas might be the control head on the dash (a known problem on the 2001-2006 Sebrings) and the body computer which controls the whole HVAC system based on inputs from the controls on the dash.
Chasing down multiple possible causes on a problem that's intermittent is something like a game of whack-a-mole. You're never really sure the problem is fixed and if it eventually goes away, you're never sure what caused it and which of your repairs actually fixed it.
Old Jul 4, 2017 | 01:59 AM
Ericbo101's Avatar
Default More details on how intermittent !
Thank you dcotter0579, very much appreciated !!
Now having tested the aircon a bit more, I have some new information that could help pinpoint the failure: it works for about 20 minutes then stops working. You have then stop the aircon for an other 20min and it will work fine again for 20min
Appreciate any input about what that could mean !!
Your appreciative site member
Old Jul 4, 2017 | 09:50 AM
The HVAC system is controlled by the body computer, as I noted above. Also involved is the control head on the dash. Both have circuit boards. Circuit boards can be subject to intermittent failure when they heat up, expand a little bit and lose continuity at a weak solder joint. When they cool down and contract continuity can be re-established. Not saying that's your problem but maybe it could be. Following the "when in doubt, replace the cheapest things first" philosophy, you might want to replace the control head to see if that does the trick. Others have had success opening it up and re-soldering the joints on the circuit board. If you're good with a soldering gun, you could give that a try. Because of the cost, the body computer should be farther down the list of things to try.
Other possible areas of concern could include the expansion valve and the receiver/dryer, which could be partially plugged.
You say you "recharged it a couple of times". Are you sure you didn't over charge it? Why would it need charging more than once? The only way to be sure you have the correct charge in there is to evacuate the system and add back in the correct amount.
Old Jul 11, 2017 | 02:06 PM
Ericbo101's Avatar
That is really great information dcotter0579. I just checked and can find the control head on Amazon (see the link). For the recharging, it has been over 10 years and it does the trick each time (really cold now when it works)
Amazon Amazon
Thank you again, will let you know ! ericbo101
Old Jul 16, 2017 | 06:32 PM
Ericbo101's Avatar
Got the control head from Amazon within few days and changed it (5 minutes ...)
Of course it worked when I started it and drove, will test run for a week or so before declaring victory ...
But dcotter0579, owe you and would love to send you some gift card if you do not mind sharing an email address
Old Jul 16, 2017 | 06:51 PM
Glad it has worked out. That's plenty of thanks.
Old Jul 21, 2017 | 03:05 PM
Ericbo101's Avatar
Most welcome dcotter579 !
Unfortunately by day 3, was back to the intermittent problem
What do you think would be the next best step ?
Happy to keep repacing until it works ... teaches me aircon !
Thank you so much
Old Jul 21, 2017 | 05:43 PM
See if the blend door is working properly. If it's not working then you'll need to determine if the problem is the actuator or the computer that controls the actuator. If that's not the problem you might want to try replacing the expansion valve and the receiver/dryer. Since you have to replace the freon to do either, might as well do both.
You'll probably have it figured out by December. BTW, there are books on repairing the A/C system. Might be worth the investment.
Old Aug 6, 2017 | 04:50 PM
Ericbo101's Avatar
Thank you dcotter0579 !
I tested the aircon and found the cooling lines hot while on aircon so doubt it is a blend door issue ... Got myself the AC system repair book and ordered the expansion/receiver/dryer
More soon !
