Low beams quit, no light flashes on lock or unlock
Old Jun 30, 2007 | 08:41 AM
cgaeth's Avatar
Default Low beams quit, no light flashes on lock or unlock
Hi there,
I am hoping someone can help with this one. On my wife's 2005 Sebring Sedan the low beams just quit working. The hi beams work fine. I have checked all the fuses and they are good. In the process of looking into this issue I noticed that when you lock, unlock, or even hit panic on the remote her lights no longer flash. I am guessing this is all releated. Any ideas on what I need to do to fix this?
Old Jun 30, 2007 | 10:07 AM
Default RE: Low beams quit, no light flashes on lock or unlock
possable multifunction switch or BCM
Old Jun 30, 2007 | 04:00 PM
cgaeth's Avatar
BCM? Body Control Module? Is there another relay in there some where that is not listed in the little owners manual?
Old Jun 30, 2007 | 10:37 PM
yes BCM Body control Module we dont use relays for headlights ne more most now a days most are pulsewith controled by a computer.
Old Jul 4, 2007 | 07:01 AM
cgaeth's Avatar
Darn. That was not the answer I was hoping for. How can troubleshot this so I know for sure that it is the BCM? Where can I get one and how much should one cost? Is this something that a shadetree mechanic should even mess with?
Old Jul 4, 2007 | 10:39 AM
for u i would try the muitifunction switch first thats the headlight and turn switch. U would not be able to troubleshoot this from a BCM perspective. U would haft to see what the bcm is seeing inorder to say that yes the input and outputs are working correctly.
Old Jul 4, 2007 | 11:08 AM
bandaide's Avatar
ORIGINAL: cgaeth
Hi there,
As silly as this sounds, have you checkedor replaced the bulbs to see if the elements for the low beam are still good? I've had my Sebring Convertible for 3 years and replaced the bulbs it came with about a month after I bought it. I went with the SilverStar bulbs knowing that they are brighter but have a shorter life. I've had to replace those just about each year. One failed and the another about a week later.
wig6516
Feb 6, 2016 08:10 PM
Big_Rob
Nov 25, 2012 12:17 PM
johnseattle
Jun 20, 2008 07:47 PM
johnseattle
Jun 20, 2008 02:11 PM
