New radio infinity help
Old Dec 27, 2008 | 11:04 PM
artvandelay's Avatar
Default New radio infinity help
Hello again,
I'm going to bother you all with another new guy question. I just bought a new pioneer head unit for my 99 JXi convertible. I have put in new decks in all of my previous cars. I am not a wiring genius, every time I mess with a wiring harness I just put the like colors together and it has always worked. I tried searching the infinity bypass, and it got a little to technical for me to read. The only place in my area that does installs is Bestbuy and I do not trust them to not screw it up. I found this during my search. What do you all think? If this is not what I need, does anyone have the time to walk me through how to do this?
http://www.installer.com/item/displa...php?it=70-1818
This is the head unit I ended up getting
http://www.pioneerelectronics.com/PU...ier/DEH-P700BT
Thanks again.
Old Nov 11, 2010 | 07:42 PM
mjermine's Avatar
You don't need to bypass the Infinity Amp if you are just replacing the head unit.
Just note that the Amp will turn off when switching from radio to CD because the amp on/off is based on the line voltage of the antenna power supply wire. Switch the amplifier turn-on wire with the antenna power supply to fix the problem and make it work for the Sebring Sedan/Convertable.
Old Nov 11, 2010 | 10:13 PM
A visit here might prove useful:
http://www.the12volt.com/
Let us know how it works out.
randy48
Mar 31, 2011 01:53 PM
Atap123
Oct 9, 2009 04:25 AM
FitPaul
Oct 8, 2007 08:35 AM
quattj
Jan 17, 2007 02:41 AM
quattj
Dec 23, 2006 10:31 PM
