Newbie: Stereo Rocker Switch Problem
Old Apr 24, 2007 | 02:29 PM
laszlo's Avatar
Default Newbie: Stereo Rocker Switch Problem
I have 2004 Sebring Convertible.
The Rocker Switches on the SteeringWheel (both sides)for the stereo are not working? Any ideas what is wrong?
My car only has 19,805K on it and I have had nothing but problems with it from Passenger side roof leaks to CD not Ejecting to Oil leaks to Car doors not aligning properly. Does it ever stop?
Can you help me with the Rocker Switch Problem?
Laszlo
Old Apr 24, 2007 | 06:44 PM
Default RE: Newbie: Stereo Rocker Switch Problem
unsder warranty??? take it to the dealer if not then u need to see if the signal is being sent or getting to the radio from the switches. if both dont work then i would say radio,connector,or wire issue. Leaks haft to have some one with leak experence take care of that. Radio issue is a radio.
Old Apr 24, 2007 | 07:11 PM
laszlo's Avatar
It is not under warranty
Are you referring to water leakage into the vehicle? If so where would the water leak have to come from?
The Radio works and the CD player works... the switches on the Steering Wheel that allow you to change volume, mode, tracks (the Rocker Switchs) are not working, nothing happens when I push them.
Any ideas?
Laszlo
Old Apr 24, 2007 | 08:04 PM
radio switches
water leak
Leaks haft to have some one with leak experence take care of that outside company
lovemy88chrysler
Nov 13, 2008 08:51 PM
nibbes123
Sep 13, 2008 07:41 AM
jtrent
Mar 5, 2008 12:07 AM
mack324
May 23, 2007 02:47 AM
BLUENEWPORT
Jan 10, 2007 03:45 PM
