No Heat in 99 sebring conv
Old Dec 1, 2012 | 05:30 PM
mitalie1's Avatar
Default No Heat in 99 sebring conv
My car has NO heat. I have tried replacing the thermostat, radiator cap, water pump. I have flushed the radiator by hooking a hose to the heater line so it flows through the core. I have made sure to get the vapor lock out of the heater hoses. I have checked the duct work.
The heater hoses do not get hot when the rest of the hoses do.
What am I missing?
Old Dec 1, 2012 | 06:43 PM
the u have a clog in the heater core
Old Dec 1, 2012 | 07:54 PM
mitalie1's Avatar
I've flushed the heater core twice.
Old Dec 2, 2012 | 12:23 AM
your heater core is clogged up
Old Dec 22, 2012 | 07:32 PM
zgadson's Avatar
Could also be air at the top of your radiator. Even if your reserve reservoir shows it's got enough coolant, open the radiator cap [when the engine is cool] and if you can see the top of the fins inside, you need to add more coolant.
Old Jan 2, 2013 | 07:15 PM
Tommy Martin's Avatar
Could be your blend door too. Just went through this on a Jeep. Do both your heater hoses get hot?
Old Jan 2, 2013 | 09:30 PM
that is not a blend air door issue
Old Jan 3, 2013 | 05:55 AM
I agree 100% with that. I didn't originally see the part about the heater hoses not getting hot, and that's why I asked about them getting hot. I guess I shouldn't try to read things when I'm half asleep. Time for a heater core!
Old Jan 3, 2013 | 01:08 PM
=) more then likely
Old Jan 12, 2013 | 08:02 AM
Originally Posted by wionesc
The heating unit lines do not get hot when the relax of the lines do.
Then I'm 99% sure your heater core is clogged.
