no spark 2000 sebring what happened ?
Old May 14, 2011 | 12:55 AM
PBrowning's Avatar
Question no spark 2000 sebring what happened ?
I did a major timming belt service on this car including the valve cover gaskets and plugs. started car and all was good ran for 20 min no check engine light. let car sit for a few min and engine misfired upon restart and would not go away. traced fault to #5 fuel injector open cicuit when hot. replaced injector reconnect battery and now no spark. I have injector signals. checked asd and found no signal from PCM to switch on relay. I can jump terminal #4-r/w wire at relay and relay switches on. is it possible the pcm has corrupt data and needs reflashing? alarm fault? any kind of hard reset to perform? Help please P.B.
Old May 14, 2011 | 06:20 PM
Djinn-n-Tonic's Avatar
Just a guess.....2.5 V6?
With a 12 volt test lamp...Clip on ground..
Probe ASD output to injectors. Turn the key on, but dont start it..the lamp should light up for 2 seconds and go out....
Now Crank the car. the lamp should light up while cranking .
Post back the results...
Old May 14, 2011 | 10:43 PM
PBrowning's Avatar
yes 2.5. I have injector pulse to injectors. no signal from pcm to asd relay to energize it. as I posted, I can jump the relay to ground at terminal 4 on relay(red/white wire from pcm) and relay will energize.
Old May 14, 2011 | 11:41 PM
The reason I said to do it the way I mentioned is to Verify CKP signal..... There is a 2 second fuel pump prime pulse, But after that.. ASD is dependant upon Crank sensor rpm signal to engage. If you have PRIME, But no ASD WHILE CRANKING...PCM is not recieving a CKP signal.
Will the car start with the relay Jumpered?
Old May 15, 2011 | 12:10 PM
PBrowning's Avatar
no it still wont start. I have a led pluged in the injector conector and can see light flash when cranking. I will check to see if it lights on start up. I see what you mean by using chassis ground, so I will try that too. I'll post back, Thanks.
Old May 15, 2011 | 12:17 PM
Are you using BOTH terminals of the connector for the LED????
If you are ..Then ASD MUST BE WORKING....The + side of the injector comes from ASD. If ASD doesnt engage.....You will have NO POWER to Injectors, Fuel pump, Coil, and possibly OXY sensor heaters.
Old May 15, 2011 | 02:21 PM
PBrowning's Avatar
Ok so I have 12v when switched on. and battery voltage when cranking. looks like I was wrong about the relay not getting signal. so I'm guessing the coil went out?
Old May 15, 2011 | 02:46 PM
Go over the wiring harnesses for anything That you may have overlooked....
Those cars ALL had Distributor issues, and They arent cheap, So make sure you arent chasing "GHOSTS".....
The rear Plugs are a pain to get to, but pull one of the Front wires off, and make sure there is a spark coming from the distributor while cranking.
Old May 15, 2011 | 03:25 PM
PBrowning's Avatar
there is'nt a spark. I'm going to take off the dist cap and check to see if 12v at coil terminal, should be 12v if its ok right?
Old May 15, 2011 | 07:48 PM
It should co-incide with ASD reaction.....
