p 1684 error code
Old May 12, 2008 | 10:27 PM
gackster's Avatar
Default p 1684 error code
got this code after check engine light came on for my 2002 sebring. 4 cyl
Old May 13, 2008 | 08:09 AM
Default RE: p 1684 error code
Don't worry about that one. It's not the one that lit the light. P1684 merely means that the battery was disconnected within the last 50 start cycles. If the check engine light is on, there's something else going on.
You might want to invest in an OBD II scanner. They cost about 50 bucks on eBay. The dealer will charge you over 80 bucks just to hook theirs up and read the codes once. It's worth the money and will let you discuss the problem more intelligently with your mechanic.
Old May 14, 2008 | 12:11 AM
irdaneel's Avatar
If it stays on and that is the only code, then try disconnecting the battery and touching the ends of the cables together (not connected to battery!). Sometimes that confuses an overly sensitive electrical system into submission. (Not often, but it's cheap and worth a try. It's good maintainence anyway.)
joeuc23
Oct 2, 2011 06:16 PM
COMPADRE
Jul 16, 2011 01:41 PM
abiffmaster
Aug 28, 2007 11:00 AM
dslben
Jun 24, 2007 11:55 PM
drw170
Jun 22, 2007 09:11 AM
