P765
Old Dec 1, 2012 | 10:10 AM
RSAutry3's Avatar
Lightbulb P765
I have code P765 on my 1999 Sebring lxi, transmission shift solenoid D "malfunction." Where is this device?
Old Dec 1, 2012 | 10:48 AM
There's a solenoid pack on the front face of the transmission that is usually visible and accessible from above after removing the air cleaner box. Search the forum here for several threads discussing it. It's a relatively easy DIY repair. The part is widely sold.
Old Dec 1, 2012 | 07:37 PM
RSAutry3's Avatar
Thanks, I kinda thought that was it, just wanted to be sure.
Old Jan 18, 2013 | 05:35 PM
RSAutry3's Avatar
Question 1999 Chrysler Sebring lxi Code P1768
Gotta new code on my 1999 Sebring....P1768, transmission circuit relay...where is it and how do I fix it?
Old Jan 19, 2013 | 08:31 AM
Fuse box under the hood. Look for a legend on the underside of the cover. Replace the relay.
Old Jan 23, 2013 | 04:19 PM
RSAutry3's Avatar
Default Still TCM issues
Got rid of the last code but I can't get rid of an "old" one....what turns on the "Service engine soon" light, not the "Check engine light", and how do you get rid of it? I keep getting "solenoid malfunction" lights but the solenoid pack has been replaced and the connectors were cleaned with contact cleaner and the codes went away for a while but came back a short time later. I can disconnect the battery and everything is O.K. but then the "solenoid" codes come right back and .......the same over and over!!!! HELP!!!!
Thanks,
RSAIII
Old Jan 23, 2013 | 07:43 PM
Check engine light, service enginge soon light, malfunction indicator light. They're the same thing. Get the codes, find out what is wrong, get it fixed.
Check Engine Light | Resetting Check Engine Light | Service Engine Soon Light | RepairTrust.com
