PCM Phantom Codes
Old Jun 7, 2023 | 01:43 PM
JokingScholar's Avatar
Default PCM Phantom Codes
I purchased a 2007 Chrysler Sebring that I am trying to clear codes on. The codes are as follows. P0300, P0301, P1607, U1110, U1120, U1412, P0335, U1403, P0700. I started by replacing the battery as it was shot. This didn't clear any of them. (I didn't expect it to, but I know it is a factor in some cases.) The first I was trying to tackle was the P0335. I replaced the CKP but the code did not clear. In looking into this code and several others it seems like a faulty PCM can cause these issues. The previous owners did replace their PCM just before they parked this car for several years. I am not sure if I should try and reprogram, replace, or pursue another avenue I haven't thought about. To be clear the vehicle drives perfectly. There are no hesitations, misfires, difficult starts or shifting issues I can detect. Any ideas or direction would be greatly appreciated!
Old Jun 7, 2023 | 08:26 PM
Biffford's Avatar
Those are misfire codes right? Hopefully this isn't your problem but my cousin had those codes and it was timing belt. It wasn't a sebring tho.
Old Jun 7, 2023 | 10:38 PM
Some of them are, but I am not having any misfires occurring
Old Jun 8, 2023 | 03:03 AM
Biffford's Avatar
How's the transmission? That p0700 is a transmission code. The car might have more problems than its worth. I hope not but maybe. What does the fluid look like?
Old Jun 8, 2023 | 07:22 PM
Checked the transmission fluid, it is clear. No particulates. The car also had no issues shifting gears, driving or going in reverse. No odd sounds or vibrations I can detect either.
Old Jun 8, 2023 | 10:53 PM
Biffford's Avatar
for the p0700 code it says probably TCM. I can't even find one for your car. There's a solenoid. Maybe someone else who's knows more will chime in.
Old Jun 11, 2023 | 05:45 PM
P0700 means that there is a transmission fault code stored in the computer. You need a more sophisticated code reader to drill down to find out what that specific code is. The misfire codes could be something simple like a worn spark plug. Could also be something like a clogged fuel injector. Try a can of fuel injector cleaner. Cheap, might help, can't hurt.
powerpak
Nov 6, 2019 06:26 AM
riverrat395
May 17, 2013 04:02 AM
Mausea
May 25, 2012 01:32 PM
AdamStrad37G
Mar 19, 2012 06:59 AM
nellis003
Nov 20, 2008 10:48 PM
