Radiator fans - high speed failure
Old May 6, 2011 | 07:34 AM
Laimon's Avatar
Default Radiator fans - high speed failure
Sebring sedan 2.7l 2004
Last week I noticed a higher engine temprature when A/C is on. I later realised that fan speed is at low all the time.
Checked fuses and relays no code came up.
any ideas ?
Old May 6, 2011 | 10:38 AM
the high speed fan will come on at 220
Old May 6, 2011 | 11:58 AM
Laimon's Avatar
engine reach away more than 220 !! they also should come when certain pressure in a/c system is reached. They used to work and now I have noticed that they don't at all and i'm getting upnormal temprature readings ..
Old May 6, 2011 | 02:26 PM
check fuses check the fans see if they come on when adding power right to them
Old May 7, 2011 | 11:43 AM
Laimon's Avatar
ok I disconnected temprature sensor and low speed only came on. I checked relay it is working even I have switched low speed relay with high speed to make sure both work and they are ok.
High speed not working
Old May 7, 2011 | 09:29 PM
the temp sensor is doing its job if the gauge is showing the temp of the car its working just fine.
have u checked the fuses or am I just talking to myself?
Old May 8, 2011 | 01:30 PM
Laimon's Avatar
Yes I did check all fuses and both relays. engine temprature is very high just before red mark. i always switch off a/c when i get to this level. a/c performance is poor too.
Old May 8, 2011 | 05:32 PM
get a wire diagram and make sure the is power and ground to both high and low speed fan relay
Old May 9, 2011 | 01:41 PM
Laimon's Avatar
you will never believe what happend !! :-D
I was angry so I did hit power distribution center with a screw driver ... and high speed kicked on :-D
I have wiring diagrams so I'm going to check what is bad connection in that center.
I drove the car then If I have stolen it, looks good but heat gage fluctuates, perhaps bad thermostat from overheating for couple of weeks ..
Old Mar 27, 2013 | 06:18 AM
3500 Golf's Avatar
Just recently started having a problem with a 2004 Sebring convertible 2.7L running hot when stuck in traffic for extended time. What is the best repair manual that will help me troubleshoot this problem by showing the following: sensors and locations, relays, fuses, wiring diagrams. Also need info on which fan is high speed, which is low and when they come on.
FURTHER INFO - replaced a leaking water outlet housing 2 years ago and temp used to read about 3/8, but now rarely goes to 1/4. Tried to take sensor out of old housing, but it kept spinning, so I didn't try to get the existing one out. Does this temperature sensor control radiator fans?
When the car was running hot, temp gauge was reading above 1/2 and oil light flickered. (synthetic oil changed every 3500 miles, so don't believe sludging to be a problem) Turned on heater, windows opened and fan on high made temp go down to normal range.
At home, started the car, put the a/c on and both fans both came on after a delay and cycled on and off. The a/c clutch didn't engage. Haven't used the a/c in months, but it worked well back then.
