replace belt on '10 2.4
Just opened the hood on my daughters Sebring looking to change the serpentine belt. But,,,, cant for the life of me find a tensioner pulley or similar? So how exactly do I loosen this thing so I can get it off and on? Googled it but cant seem to find the right year,,, Thx Cory
If it's anything like my 2010 2.7L , the tensioner sits between the crankshaft pulley and the alternator pulley, in between them, but above both. (so the three create a triangle).
You need to remove the RH wheel well splashguard. Look for the smallest pulley of the bunch there. You need to place a ratchet/box end wrench and move the pulley counter clockwise in order to release the tension on the belt. |
Originally Posted by Lug
(Post 100563)
Originally Posted by Cory Cuneo
(Post 100565)
Thank you, and Im guessing the wheel has to come off also?
if you're new to this, don't work under a jack only, purchase jack stands and support the car from the front of the pinch rail. |
This is from a 2.7L motor drawing, yours may vary, I'm not sure. But if they are the same, #7 is what you're looking for.
https://s21.postimg.org/nzyfnxhcn/Capture.png |
(Post 100567)
As long as Google is not ****ting it, here's an actual image of a 09 2.4L
In this image, it appears to be #2. BTW, in some vehicles there's a diagram of the serpentine belt routing, on the bottom side of the hood. http://i.fixya.net/uploads/images/d379ab8.jpg |
(Post 100572)
Originally Posted by esu
(Post 100751)
OK, sorry for the delay, got caught up in 7 other projects, this diagram is not the motor in her car. She has the 3 smaller pulleys but they are clustered on the right side in between the ac compressor on the bottom and the ps pump on the top or 3 and 4 in the diagram. None of them are on a swing arm type of assembly, it appears they all bolt directly to the engine?? The bottom one I cant see that clearly, maybe there is some type of adjustment on it?
That, will tell you exactly how your engine is set up, and leave very little doubt. It's either that, or Google (sometimes you just can't find the right answer), or for someone with the similar motor as yours to reply. |
| All times are GMT -5. The time now is 04:27 AM. |
