Sebring 07 Sound Connection
Hello, Im trying to connect a Rockford Fosgate Amplifier to my 2007 Sebring but i cant find a hole or slot where to get the wire from the battery (+) to the interior of the car, its totally sealed.
If anyone have a sound system installed please help me.
regards.
regards.
Hunt around on this site:
http://www.the12volt.com/
You'll probably find your answer. Keep in mind that the old radio needed the same power feeds that your new radio needs, so the wires are probably right there already.
you might have to drill one of your own because the battery is in front of the driverside tire or go off the post on top and drill a hole through the firewall but becarefull you dont drill into anything importent
I just had the same issue with my Concorde,I didn't want to drill any holes in my firewall,so I routed my 4 gauge wire under the car to the back and drilled a hole in back of the tail light into the trunk.Its looks good,can't see the wires.The remote wire from the trunk to the dashboard was easy,I'm sure you won't have any issues with that.My batter is also in the fender well,so I hooked up my wire to the fuse box under the hood and it makes for an easy access.
arenty
Dec 31, 2010 02:27 AM
Timmb
Apr 13, 2009 10:34 PM
