Sebring 2001 Check/Remove Blend Door Actuator
Hello
When turning the heating controller to hot, the heating does not work. Is there a possibility to check : Is the Blend Door Actuator working? Regards |
First thing to check would be to make sure your coolant level is where it should be. Then check control box itself. It's quite easy to remove and it used to be cheap to replace. If you're good with a soldering iron, you may be able to repair it.
(Post 118760)
I had to recalibrate the doors https://cimg1.ibsrv.net/gimg/www.chr...d383f23c08.jpg I put the controllers in the shown position and pressed for 20 Sec the button below the finger. Below the miles in the odometer was shown AC 00 I had to wait til that information disappeared And everything was fine Regards |
Blend door actuator.
Originally Posted by sebringtom
(Post 118764)
It looks like that I have found the reason why it did not work.
I had to recalibrate the doors https://cimg1.ibsrv.net/gimg/www.chr...d383f23c08.jpg I put the controllers in the shown position and pressed for 20 Sec the button below the finger. Below the miles in the odometer was shown AC 00 I had to wait til that information disappeared And everything was fine Regards Hi I never heard of recalibrating the doors. I wonder if this will work for me. The guy i bought the car from used to reach behind the glove department and turn something in order for him to go from heat to ac. But now that it’s set on heat the only thing I can control is the fan. |
