Sebring 2001 Check/Remove Blend Door Actuator
Old Jul 10, 2021 | 04:07 AM
sebringtom's Avatar
Default Sebring 2001 Check/Remove Blend Door Actuator
Hello
When turning the heating controller to hot, the heating does not work.
Is there a possibility to check :
Is the Blend Door Actuator working?
Regards
Old Jul 10, 2021 | 08:55 PM
First thing to check would be to make sure your coolant level is where it should be. Then check control box itself. It's quite easy to remove and it used to be cheap to replace. If you're good with a soldering iron, you may be able to repair it.
Old Jul 11, 2021 | 10:43 AM
sebringtom's Avatar
It looks like that I have found the reason why it did not work.
I had to recalibrate the doors
I put the controllers in the shown position and pressed for 20 Sec the button below the finger.
Below the miles in the odometer was shown
AC 00
I had to wait til that information disappeared
And everything was fine
Regards
Old Nov 12, 2023 | 04:04 PM
60438's Avatar
Default Blend door actuator.
AC 00
Regards
Hi I never heard of recalibrating the doors. I wonder if this will work for me. The guy i bought the car from used to reach behind the glove department and turn something in order for him to go from heat to ac. But now that it’s set on heat the only thing I can control is the fan.
Raider
Sep 21, 2021 10:42 PM
Jsmitty0823
Jun 10, 2021 05:27 PM
Jsmitty0823
Jun 9, 2021 08:21 PM
Shenny
Nov 4, 2017 02:58 PM
Jwrbloom
Oct 15, 2013 03:46 PM
