Sebring shows codes P0016 and P0344
I have a 2006, 2.7, 6 cil., Chrysler Sebring and after I overhauled the engine, I have to try a few times before engines starts, in idle it works smoothly but cannot pass 2400 revolutions because it starts to fail as soon as it lowers 2400 rpm it`s ok. It shows code P0016, P0137, P0138 and P0344. Can anyone help? Thanks
Just found this site, Might help. http://www.allpar.com/fix/codes.html
P0016 Cam/Crank Timing Misalignment and P0344 Cam Sensor Imtermittent you need to be concerned about. What exactly did you do on this rebuild? As in what parts did you replace new?
The other 2 codes are for low and high voltage on O2 sensor 1/2. You probably chaffed some wires on it OR it's just bad. |
I replaced the timing chain (the long one and the two short ones) and their guides, tensors, etc. The cilinders, the valves, all the gaskets, the camshaft sensor, etc.
Originally Posted by nasser
(Post 40059)
