Sebring shows codes P0016 and P0344
Old Aug 25, 2010 | 05:42 PM
nasser's Avatar
Default Sebring shows codes P0016 and P0344
I have a 2006, 2.7, 6 cil., Chrysler Sebring and after I overhauled the engine, I have to try a few times before engines starts, in idle it works smoothly but cannot pass 2400 revolutions because it starts to fail as soon as it lowers 2400 rpm it`s ok. It shows code P0016, P0137, P0138 and P0344. Can anyone help? Thanks
Old Aug 25, 2010 | 07:28 PM
shamrock249's Avatar
Just found this site, Might help. http://www.allpar.com/fix/codes.html
Old Aug 25, 2010 | 07:34 PM
TNtech's Avatar
P0016 Cam/Crank Timing Misalignment and P0344 Cam Sensor Imtermittent you need to be concerned about. What exactly did you do on this rebuild? As in what parts did you replace new?
The other 2 codes are for low and high voltage on O2 sensor 1/2. You probably chaffed some wires on it OR it's just bad.
Old Aug 26, 2010 | 08:56 PM
nasser's Avatar
I replaced the timing chain (the long one and the two short ones) and their guides, tensors, etc. The cilinders, the valves, all the gaskets, the camshaft sensor, etc.
Old Aug 12, 2021 | 11:45 PM
Gabrielvilla's Avatar
friend how did you solve the problem?
Jfizzle
Feb 22, 2020 04:37 PM
umoms
Nov 29, 2013 03:52 PM
geegar233
Dec 13, 2012 07:27 AM
momzilla
Jun 5, 2012 09:58 PM
2003sebring
Feb 19, 2011 07:48 PM
