Sebring Surging and Stalling but running perfect
Old Jun 9, 2016 | 08:16 PM
Stupidav's Avatar
Default Sebring Surging and Stalling but running perfect
I have an 08 Sebring, runs like a champ no missing, nice idle ~700rpm, plenty of power, getting good gas mileage.
Randomly when approaching stop sign or light, while applying brake the car will surge ahead, without noticing any major change in RPM (cause it scares the crap out of you and you have to really hit the brakes). At other random times the car will just stall typically while going at some slow idle or just over idle speed. One time it stalled 4 times going across a parking lot, then it might not do it for a couple of days. May or may not be related, the car went through a set of brakes in 4 months. Replaced everything on them, calipers, rotors, pads, ect. There is also an occasional clunking noise that comes from the front end, haven't found where from but possibly the transmission.
The Throttle Position Sensor has been replaced. The intake Manifold has been replaced. Dealer wants to replace the computer although they can't guarantee that it will fix the issue and at $1100 installed it is a chance I am not sure I want to take.
I have read people talking about EGR valve (not sure if this has one yet), although they describe their problem including a rough idle. I have also seen people talking about the Speed Sensor in the transmission although I haven't seen anyone that said whether or not it worked.
Any help is greatly appreciated!!!!
Old Jun 10, 2016 | 08:58 AM
Do you drive with your left foot on the brake and right foot on the gas?
Old Jun 10, 2016 | 11:06 AM
Stupidav's Avatar
One foot only, driven the same way for years and now this.
Old Jun 11, 2016 | 11:10 AM
I asked because you described the brakes being in need of total replacement. There are people who brake with the left foot who ride it constantly to regulate speed while pressing on the gas all the time.
Anyway, that's not helpful here. That "clunk" you described might be a loose engine mount. It's not impossible that if the engine is moving around excessively, the throttle cable could be affected. It's worth checking.
Old Jun 13, 2016 | 08:11 PM
jopizz's Avatar
I had a similar problem years ago with a GM car. It would surge and stall out when I put on the brakes. It turned out to be the crankshaft position sensor.
John
Old Feb 19, 2017 | 10:49 AM
dna9656's Avatar
Wagner had a run of warped rotors. Tell me HOW do you get warped rotors when you have to machine the thong after it's cast...negligence, pure negligence. So I now do not EVER purchase or pay for a rotor from Wagner. 2 sets from Auto Zone, the one I paid for and the replacement set (under warranty) they provided. I turned the 2nd set at their expense. Still on the car.
Old Feb 19, 2017 | 10:55 AM
dna9656's Avatar
Default Stumbling
Did you get any resolution? Fixed? If so what was the magic potion?
Old Sep 5, 2025 | 01:49 PM
mba's Avatar
mba
Default Any solution.
Did you find a solution?I have the same problem.
sseverett
Jan 4, 2017 04:39 PM
Chrysler Forum Editor
Jan 11, 2016 08:40 AM
riggsauto
Jun 28, 2013 07:49 PM
srt4_night_rider
Feb 15, 2006 01:49 PM
May 12, 2005 08:42 PM
