squeeling sound!!! NEW?
Old Nov 11, 2007 | 12:15 AM
ryanb4614's Avatar
Default squeeling sound!!! NEW?
i just got my timing belt,tension pully, idler pully, water pump, cam shaft seal, air cond belt, alternator belt replaced on my 1998 sebring coupe lxi.... when i turn it on it squeels real loud for a couple of seconds around 45 se or more then if i turn on my air (heat) it squeels even more... what the hell can this be, i think either two things: belts to tight or loose OR the belts needs to set in?
Old Nov 11, 2007 | 10:37 AM
bandaide's Avatar
Default RE: squeeling sound!!! NEW?
My thoughts would be the exterior belts are probably a little loose. You may want to readjust those.
Old Nov 11, 2007 | 07:40 PM
moe's Avatar
moe
yeah belts are loose,belts don't require break in time.moe
Old Nov 11, 2007 | 11:03 PM
ryanb4614's Avatar
alrite thanks called the guy that did it, hopefully he doesnt try to screw around... any one know if they make a universal weatherstrip to go around a sunroof.... my sunroof rattles alot i tightened all the torex bolts that i could see on the sunroof so my guess is the weatherstrip
Old Nov 12, 2007 | 07:49 AM
moe's Avatar
moe
Hey ryan that's a dealer only part.there might be after market parts but might make the leak worse.moe
Old Nov 12, 2007 | 12:44 PM
ryanb4614's Avatar
it doesn't leak at all, but it rattles crazy very annoying, and when i slam the door close the window will pop up, but i thought maybe something was loose but i tighten the 2 torex on each side of the sunroof and the frame...
Crazyotto
May 24, 2012 07:21 PM
catchingcolds
Aug 16, 2009 06:26 PM
sirlawrence1
Jun 22, 2008 12:13 PM
Nov 23, 2005 12:31 AM
cajundaddy
Nov 20, 2005 08:50 PM
