Strange pin holes in 2004 Sebring 2.7L intake plenum
Old Feb 23, 2024 | 06:13 PM
mopar67440's Avatar
Cool Strange pin holes in 2004 Sebring 2.7L intake plenum
I just purchased a very clean 2004 Sebring Convertible Touring with 46k miles.
Been going thru all the maintenance and repairs, when I discovered small holes next to 3 of the 8 intake plenum bolts. The appear to be random sizes approx 1/16"
Not sure if the plenum is defective, and if they are lending to a slight vacuum leak
Using a rubber hose as a stethoscope, it sounds like there might be air entering the intake air stream.
This would effect the 02 and MAF sensor readings if these are indeed small vacuum leaks.
The engine runs nice, however I've seen cleaner plugs in my 02 Sebring with 144k miles.
Anyone ever notice this and look into it?
Very strange.
Old Feb 23, 2024 | 09:03 PM
sota's Avatar
never seen them on mine, but then never looked for them. they could be drain holes to let water out if it gets in there.
Old Feb 24, 2024 | 05:41 AM
mopar67440's Avatar
Drain holes would kind of make sense...but they're only at 3 of the 8 bolts, and there is no place for the water to drain too.
Also looked at my 02 and there are no holes.
Old Feb 24, 2024 | 08:36 PM
sota's Avatar
left-to-right is passenger to driver. top and bottom would be flipped. can you highlight which 3 have holes?
sebring03
Jan 26, 2017 07:03 PM
plymouth speeder
Aug 31, 2012 04:58 AM
fdfever
Oct 15, 2006 06:28 PM
fdfever
Oct 14, 2006 06:28 PM
Flockhammer
Mar 29, 2006 03:19 AM
