Tach and Odometer work intermitently
Hi, you might want to look here http://www.mrwhizard.com/services2.cfm#Start
I have an 01 sebring with" no dash lights at night" and they fixed it and sent it back the same day they recived it. Email them your problem.
Mike
Mike
I don't know if you ever found a fix for your problem. If so,can you post?
I have the same problem-intermittent tach/odometer operation. It comes and goes anytime cold or hot.
Also the tach needle has gone beyond it's rest. Somehow it ended up beyond the rest and will only move up to '0'.
Can someone please advise how to remove the instrument cluster. I'm hoping to just reposition the tach needle. Any advice would be helpful.
Thanks. Anyone?
Thanks. Anyone?
To KMusTeach:
Best guess is some sort of a relay problem.
Download a wiring schematic from Autozone.com and start looking.
To Daryl1:
There is nothing more frustrating than working in the dash of a vehicle!!!! But if your needle is below the stop I think it is unlikely that it will function properly again by just putting it back. More likely you will end up replacing it. You might try to find a source for replacement before you start the project so you can go buy it while you have it apart.
Sorry I can't help you with the tricks to open up that eggshell.
Good luck.
To Daryl1:
Good luck.
Thanks. I appreciate it. I'll check Autozone as you suggested. Looks like a bit of a chore to open that dash. It's a '96 Sebring in great shape-only 45K and definetely worth fixing. Thanks again.
Hawgfan
Jul 18, 2014 11:32 PM
Gary25
Mar 3, 2012 10:18 AM
timejerker69@yahoo.c
Aug 14, 2006 11:39 PM
2007, 96, 97, chrysler, convertible, dont, fix, inaccurate, inop, odometer, sebring, tach, tachometer, work, working
