Tranny
Old Oct 2, 2013 | 06:46 PM
maktheknife's Avatar
Default Tranny
I changed the tranny fluid and filter (not a system flush) on my 2004 Sebring 2.7L Touring and now it jerks occasionally when accelerating and sometimes when shifting from park to dirve. Any ideas on the cause of this problem?
Old Oct 2, 2013 | 09:17 PM
what fluid did u put in it?
Old Oct 3, 2013 | 08:21 AM
Atf+4
Old Oct 3, 2013 | 10:00 AM
is the o ring on the new filter?
Old Oct 3, 2013 | 01:49 PM
Yes I did
Old Oct 4, 2013 | 12:07 AM
i dont know what to tell u Something is or was not done correctly I personally Have not had an issue like that happen after doing a trans service.
Old Oct 4, 2013 | 07:49 AM
Breaking300's Avatar
Was this the first time you changed the fluid?
Old Oct 4, 2013 | 09:58 AM
Did you clean the magnet in the bottom of the pan and put it back where it was?
Try disconnecting the battery to reset the computer. That should initiate the learning cycle which may smooth out the shifts after a couple of days. If the rough shifts continue, you may need to take it in to see if any error codes are being thrown. Not just any code reader will be able to get to the transmission codes.
Old Oct 5, 2013 | 08:18 AM
It's the first time I changed the fluid on this car. I did cleaned and replace the magnet.
Old Oct 5, 2013 | 11:23 AM
Thundercraft's Avatar
It could be TCM issues.
This write-up may help
http://www.amsoil.com/technical_serv...spx#drivetrain
when you get to the page, click on drivetrain and then it is the 3rd link down
