water in oil
Old Jan 9, 2020 | 08:54 PM
Lugnut#38030's Avatar
Cool water in oil
Ive got a 03 Sebring w/2.7. Theres water in the oil pan. Now usually this would indicate that There may be a blown head gasket or some other damage to the head. so i proceeded to tear into the questionable engine and discovered that there was no indication of water in any of the intake or exhaust runners, non in the cylinders or on the plugs. i was told it never over heated but used a lot of water. Due to the location of the water pump is it possible that the water pump went south and was dumping into the oil pan?
Old Jan 9, 2020 | 09:54 PM
yes common issue water pump leaking right into the oil
Old Jan 10, 2020 | 04:47 AM
GLHS60's Avatar
Mostly its the water pump gasket that's the culprit.
The water pump has 2 weep holes that leak externally when the actual pump itself fails.
The 2.7 is a great Engine if the gasket issue is caught before filling up or sludging the crankcase.
Randy
Old Jan 10, 2020 | 08:35 AM
FIREM's Avatar
Yup, Water Pump is the common culprit on the 2.7 with coolant in the oil.
Timing Chain guides should be included in the repair.
Loads of great information and help here : https://www.dodgeintrepid.net/
Very knowledgeable on the 2.7 on that site.
Joslin Carson
May 5, 2016 11:12 PM
loggerbomb
Apr 28, 2015 07:47 AM
ears18
Apr 24, 2015 10:36 PM
mgard277
Jul 24, 2012 10:11 PM
Ryder
Oct 30, 2011 02:43 PM
