weather strip
Old Oct 28, 2007 | 09:54 AM
ryanb4614's Avatar
Default weather strip
i have a 1998 sebring lxi coupe, has no fram around the window.... when i bought it i saw that there was a gap between the window and weather strip when the door was closed water would leak in.. bought new weather strip and it seals it good now but when i put the window down then back up the gap is there so i have to open my door and close it then its sealed... any ideas? can it just be the window? i have no idea
Old Oct 28, 2007 | 11:18 AM
master tech's Avatar
Default RE: weather strip
You will need to remove the side panel and door panel and adjust both front and rear windows on that side.
Old Oct 28, 2007 | 05:02 PM
ryanb4614's Avatar
you think its the window casing the problem... what do i need to adjust
Old Oct 29, 2007 | 03:09 PM
ryanb4614's Avatar
my driver door the one i have the problem with you have to slam it hard or it wont close all the way, passenger side has no problem...also i noticed when i close my doors the sun roof glass goes up in the air alittle then back down like its loose... i just bought this car and im trying to get it in the best of shape i can
Old Oct 29, 2007 | 10:24 PM
try adjusting the door striker. 40mm torques.
Old Oct 30, 2007 | 07:44 PM
ryanb4614's Avatar
adjusted everything today seems good, sunroof was little loose but it may be time for a new seal, it has 107000 but i want to get a new timing belt on before anything. Any one know... i got a remote with it has built in alarm i already set it off... But when i lock the vehicle and alarm arms it doesnt make a sound to confirm it security light goes on but nothing else no flashing lights or beep any ideas? or is that stock
gerbot_3000
May 22, 2015 03:16 PM
RacingJunk
Jan 18, 2015 08:18 AM
bluefish001
Apr 17, 2014 06:31 AM
mm9957
Apr 2, 2010 01:25 PM
medencev
Dec 14, 2006 08:07 AM
