What is bad about 2.7?
Old May 2, 2007 | 10:13 PM
car5car's Avatar
Default What is bad about 2.7?
I went to auction yesterday and Concord with bad engine was for sale. 110K miles. Some dealer said: "I knew it was 2.7, they are bad engines" So what is going bad? I have no problem fixing any engine as long as I don't need to dropsubframeto remove oil pan.
Old May 2, 2007 | 11:24 PM
jamie1's Avatar
Default RE: What is bad about 2.7?
Engine sludge is a big concern with this engine. Oil changes MUST be done every 3000 miles. Reasons vary as to why the sludge forms from a poorly designed PCV system to the thermostat mounted in the lower rad hose. The engine also has a water pump driven by the timing chain. In theory,when the water pump bearing/seal fails, the coolant is suppost to travel down a channel to outside the block. In reality,in most cases the coolant leaks into the engine oil. Oil and coolant don't mix and bearings can be toasted in a matter of minutes.
jtminnc
Oct 31, 2010 07:08 PM
ramfan5.9
Jun 26, 2007 07:07 PM
Racinfan83
Jun 26, 2007 07:03 PM
Nov 2, 2005 12:37 AM
May 1, 2005 06:20 PM
