What Battery for 2002 Sebring Key Fob?
Old Sep 9, 2024 | 09:46 AM
richardscindy's Avatar
Default What Battery for 2002 Sebring Key Fob?
Can you please tell me what battery to replace in Key Fob? Also, lately, my ignition key has been getting stuck in ignition, is this common?
Lastly, best way to get a copy of the ignition key?
Thanks so much. I'm new to forum and grateful to be here.
Cindy
Old Sep 11, 2024 | 09:52 PM
ggoose's Avatar
The most reliable way is to pop open the keyfob and look at the battery as the type is stamped on the battery.
Suggest a Dry Lube PTFE Spray as it not attract dirt or gum up. I prefer it over graphite.
If you have a gray headed key it is a security key and needs to be programmed to the vehicle. If you have 2 keys I believe you can add an additional key yourself. If you only have a single key you will likely need a dealer or locksmith.
loyercorey
Aug 20, 2018 05:23 AM
Donnyr
Dec 29, 2017 11:18 AM
Edward Josph Arellano
Dec 28, 2017 06:56 PM
voorheisb
Jan 4, 2016 03:57 PM
harleybear
Feb 22, 2014 04:53 AM
