Wheel hub/bearing housing bolts
Old Jun 23, 2019 | 04:52 PM
2004SebringSedan2.4L's Avatar
Default Wheel Hub/bearing Attaching Bolts
Where can I buy these wheel hub/bearing housing bolts? One of mine fell out, and the other two were loose. I discovered this because of a noise when I turned my steering wheel. Luckily the CV-axle wasn't damaged, at least I hope not I wasnt able to seperate the wheel hub/bearing assembly from the CV-axle. Just need to replace the bolt that was loose/fell out. The socket is a E-14 14mm Torx socket. Any info on these bolts would be appreciated.
Old Aug 5, 2019 | 12:37 PM
boatmoter's Avatar
if you were in Tampa I would loan you the tool, mine came from S&K tools,you can find them on ebay or google it since you know the correct size.. their called a Inverted Torx Socket
Old Sep 29, 2022 | 07:08 AM
claudieopel's Avatar
The hub bolts mediate the transmission of torque from the hub to the brake drum/disc and wheel disc and vice versa, as well as ensuring the strength and integrity of the entire wheel. Breakage or loss of even one bolt is fraught with serious problems, so this fastener must be replaced with a new one in case of malfunction. But before you buy new hub bolts, it is necessary to understand their existing types and design features. You can look at the catalog at scrooz.com.au; everything is quite clear.
Old Sep 29, 2022 | 12:43 PM
ggoose's Avatar
This may be the bolt you are looking for. It shows as discontinued but the part number should help you find something comparable.
https://www.stevewhiteparts.com/oem-...Y2LWdhcw%3D%3D
travelmad
Aug 28, 2013 04:36 PM
muddauber5.7
Mar 21, 2011 03:01 PM
bobby719
Oct 13, 2010 02:42 PM
gareth111278
Sep 22, 2008 11:59 AM
peteats
May 2, 2006 07:20 PM
